11
This discussion topic has been answered Discussion topic: Nothing but problems since moving to Ultrafast
This message was authored by: Ash42
My wife and I both work from home so decided to go with Ultrfast which was advised by a Sky adviser  who assured us it would be perfect and would excel in meeting our needs and devices. From day 1 we encountered problems with WiFi and connection dropping to the point where only one red light lit on the router. Turning the router on and off works but takes far too long, very frustrating especially when in the middle of a conference/teams call. There are four of us in the home and we all have mobile phone issues too with lag and pages failing to load updates crashing. The router is positioned in the middle of the property with plenty of space around it. All devices show strong WiFi signals yet all have issues at some point every day. I would like an engineer to look at the router, and also check the WiFi strength throughout the property because this wasn't done as part of the installation. We are paying more for a service (Ultrafast) that promised so much but is actually worse than Superfast 30. Please help.
Avatar for Ash42
This message was authored by: Ash42 Answer
Re: Nothing but problems since moving to Ultrafast
That's great. Thanks for the info, it's very much appreciated
@Ash42  Did you change router when changing services with Sky? Which router did you have before changing and which one do you have now with Sky on ultrafast broadband from the link below.
Avatar for Ash42
Hello Highlinder, I changed from the Sky Q Hub to the Sky Q Hub 4.2
@Ash42  Looking at your post you said it was going all the way down to a red power light does that happen a lot of time when you have these problems?
Avatar for Ash42
It's happened at least a dozen times since I had it installed which was the end of May
That's because no ISP offers such an installation service: it might be offered retrospectively under the terms of the
 'WiFi Guarantee' element of 'Broadband Boost' or the 'Enhanced Wall to Wall WiFi Guarantee' part of the 'WiFi Max' subscription supplement.
Avatar for Ash42
Fair enough, but that doesn't help with my issue.
Avatar for Ash42
But thanks anyway
@Ash42 the services of broadband enginerrs are not part of Sky'sxstandard package but do come as part of the WiFi bunndle if you cannot achieve the guaranteed 10Mb/s for Superfast ir 25Mb/s for Ultrafast in every room.
Avatar for Ash42
Thanks for your reply. I'll try contacting Sky and arrange for an engineer to come and monitor/evaluate the WiFi strength in each room. As for the router problem, there has been no 'single red light' problem for a week now but I will mention this to Sky anyway as I am not confident it won't happen again.
Thanks again for taking the time to help me with this issue.
As I noted above, they won't do so at all unless you are subscribing to the WiFi Max service in addition to the broadband (just having a Max Hub isn't enough because that's now the default Ultrafast hardware)
If the Max add-on is in place then the default action is to despatch one Max 'pod' (wireless booster) after a telephone diagnosis.
After that, it's up to Sky whether to send up to two more pods, or book a visit, or decline to offer further WiFi support and refund the supplement cost (which is what's actually 'guaranteed')
Avatar for Ash42
