Discussion topic: Not working
Message posted on 07 Jul 2026 07:57 AM
Not working
No interne
Message posted on 07 Jul 2026 08:00 AM
Re: Not working
@RachelMurray4
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Message posted on 07 Jul 2026 08:01 AM
Re: Not working
I have no internet in my house,no light on the white box but the internet on the wall is working. I have plugged and unplugged everything!
Message posted on 07 Jul 2026 08:03 AM
Re: Not working
My reply above probably crossed with your second post.
