Discussion topic: Not working
This message was authored by: Hanay
Not working
Past few days the internet and WiFi haven't been working this is unacceptable please fix this immediately
Re: Not working
@Hanay That's a call to sky for you, the Forum is Customer helps Customer and you are not talking to sky, so they will not know!
This message was authored by: Trudy65
Re: Not working
Yeah agree.   Seems to be more issues with fibre than before.   Are you on fibre too?    Sort it out Sky.  Box help is repetitive & unhelpful
Re: Not working
Thx.  Just wondered if it was just us or changing to fibre appears more problematic in general.   I will contact Sky for sure.
Re: Not working
@Trudy65 @Hanay
As @JimM1 indicated you aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
Re: Not working
@Trudy65 Been on the sky FF500 connection since 10th Mar2025, been two wan drops early on somewhere around the 1000hr connection mark with the SR203 hub, but that could have been anything, suspect maintenance as was not even aware until i looked in the stat's and log files, missed the events completely so were not even noticed.
Was EE Fibre install then back to Sky and all run owned by (OR Openreach), but really zero problems off any kind!
