Discussion topic: Not working with up stairs
This message was authored by: Pietrobuono
Message posted on 19 Aug 2026 11:00 PM
The white is not working up stairs in my house
Find out more
Message posted on 20 Aug 2026 10:07 AM
Re: Not working with up stairs
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
