6
This discussion topic has been answered Discussion topic: Not working !! Just
This message was authored by: Jennifer81
Not working !! Just
 Need help  with getting my sky working
Avatar for Jennifer81
Level 0 icon
This message was authored by: Jennifer81 Answer
Speak with a person
Re: Not working !! Just
@Jennifer81
Not a lot of information to go on there. As you've posted on the broadband board I presume it's broadband that isn't working.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Level 0 icon
Not working
Not working
Re: Not working
@Jennifer81
What isn't working and on what device ?
Level 0 icon
Speak with a person
Speak to a person
Re: Not working
@Jennifer81 wrote:
Not working
Great post 😈 If its not working then have you thought about getting it fixed 😈
Re: Speak with a person
@Jennifer81
No need for three different threads. Stick to one for the same issue.
