Discussion topic: Not received hub
This message was authored by: Jolene1111
Not received hub
I was with BT start with sky today but had no hub I'm worried I will go off and I work from home
Re: Not received hub
@Jolene1111
Hubs for new activations are normally dispatched via Royal Mail to arrive a few days prior to the activation date.
Once sent out you can usually track its progress. Have you had this notification? I suspect your activation is possibly delayed,
The postie will usually leave it hidden if no one is in. You don't need to sign for it. The postie should also pop a card through the letterbox telling you where it was left and the tracking should show some information on it too.
