5
This discussion topic has been answered Discussion topic: Not internet
This message was authored by: VM29
Not internet
I have the same problem as yesterday, I am not receiving internet connection to the hub
Re: Not internet
@VM29
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Re: Not internet
@VM29
Avatar for VM29
Wifi on/off
For the last 3 days I have been struggling with the connexion!!
Service checker says everything is good, but I can not connect to the internet
Re: Wifi on/off
@VM29
No need for a new thread. I've moved todays post into Saturdays. Did you follow all of the advice?
Avatar for VM29
Re: Wifi on/off
Nothing mate!!
It does not work
Re: Wifi on/off
@VM29
All three links work for me.
