Discussion topic: Not connecting.
This message was authored by: Joliz78
Not connecting.
I have tested my Sky and there are no problems but 2 devices won't connect. Can you help me?
Re: Not connecting.
@Joliz78
Are all the light lit as green on the hub ?
What happens when you try to connect them ?
Re: Not connecting.
@Joliz78 Here is the link from the help that may assist you!. Covered some off them as you do not say what you have!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
