Discussion topic: Not able to connect to X
Message posted on 08 May 2025 12:06 PM
Message posted on 08 May 2025 12:15 PM
Re: Not able to connect to X
Are you saying that when you are connected to your own Wifi connection then X does not load or are you on mobile data when this is happening ?
Message posted on 08 May 2025 01:00 PM
Sorry, I am not connecting properly on my phone, using X app, but when at work on a different WiFi it's perfect
Message posted on 08 May 2025 01:02 PM
So my question above still stands, are you connecting on your own Wifi network or the Sky Mobile data one - which is it ?
Message posted on 08 May 2025 01:38 PM
Well , no, my home WiFi is not connecting properly, but someone suggested that it is an app problem, which I'm trying to resolve
Message posted on 08 May 2025 01:44 PM
Is your broadband provider Sky ?
Can you use other apps and access websites without any issues ?
Message posted on 08 May 2025 02:23 PM
Yes, provider is Sky , and all other apps are working great
Message posted on 08 May 2025 04:05 PM
Try changing your Sky Broadband shield settings. You can do this via the MySky app or online here:
https://www.sky.com/myaccount/bb-and-talk/broadband-shield
Message posted on 08 May 2025 09:46 PM
Thanks a million mate, did the trick 👍👍
