Discussion topic: Not able to connecg
This message was authored by: Jules1210
Not able to connecg
When I try to join the wifi, it says unable to join.
It was set up this morning
Re: Not able to connecg
@Jules1210
Are you entering the password correct so as it is printed on the card that came with the hub, it is also printed on the hub itself.
Have you checked that you are not entering a zero instead of a letter O or a number 1 instead of a letter l or vice versa ?
