01 Jan 2025 01:14 PM
I've turned router in and off twice and both time I got connection back for 3 mins and then it went again.
now none of my mini boxes are working. All saying problem finding my sky q o. The network.
I have also restarted my maid sky q box and the mini boxes
sky q box says it looks like you do not have an internet connection
01 Jan 2025 07:48 PM
Still not working
01 Jan 2025 08:23 PM
What's the point of having this function if you do not do anything?
very disappointing
01 Jan 2025 08:41 PM - last edited: 01 Jan 2025 08:46 PM
Posted by a Superuser, not a Sky employee. Find out more@Nathan598 This is a customer helps customer community, posts will be answered as soon as someone can.
01 Jan 2025 08:43 PM
I have also restarted my maid sky q box and the mini boxessky q box says it looks like you do not have an internet connection
Hi @Nathan598
Try completing all of the following.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
01 Jan 2025 08:47 PM
I've got the same problem Nathan. Just upgraded to the Sky Max Hub and had an engineer fit 3 boosters just before Xmas. Think the Mini box may be buggered as it's quite old now so will order a new one tomorrow. Very frustrating
01 Jan 2025 09:43 PM
Note that Max booster pods cannot help with Q Mini box issues.
01 Jan 2025 09:52 PM
TimmyBGood - not sure what you mean? Can you expand. Thanks
01 Jan 2025 09:54 PM
Im having similar problems too, Nathan. My Sky Q box us saying no satellite connection, mini box not working as Q box not working 🙈
01 Jan 2025 10:00 PM - last edited: 01 Jan 2025 10:03 PM
The 2023 Max Hub and Max pods don't have the proprietary Q mesh technology (dating from 2015) so Q Mini boxes treat Max pods as non-Sky hardware and cannot use WiFi from them.
That's a decision by Sky under Comcast ownership not to hamper Max by including backwards compatibility with what's now a rather antique mesh system when it's expected to outlive Q
01 Jan 2025 10:04 PM
Ye she engineer mentioned that they don't work on a mesh system. Do the Mini box simply connects to the Pods to access the WiFi and connect to the Main Box. So is the problem with the Mini Q box WiFi related? I'm wondering if the WiFi connection on the Mini box isn't stable enough which is why it's dropping all the time
01 Jan 2025 10:09 PM - last edited: 01 Jan 2025 10:12 PM
No, Q Mini boxes don't connect to Max pods at all. In a household with WiFi Max the Minis only get their signal from the main Q box.
Realistically there's a decade in time and a change of corporate ownership between the two systems.
Well that can't be the case as surely the engineer would have told me that. The mini Q box is miles away from the main box so wouldn't be able to pick up a signal from there. The engineer told me the Mini Q box would connect to the main box via the Pods (but not as a mesh system). It has been working pretty well over Xmas - just had the problem tonight
01 Jan 2025 10:20 PM
Posted by a Superuser, not a Sky employee. Find out moreThe minis have to get to the Q direct unless you have an old school sky router/booster.
That can be done over wifi (hard, especially with a potentially competing wifi network from the Max/pods in the same household)
or it can be done over ethernet (logistically challenging for most people)
or you can use powerlines (somewhat dependent on household electrical wiring)
or you can connect each sky box into the back of a wifi mesh node (expensive but also gives you great wifi as a by-product)
@MM1986 you said "no satellite connection" - did you mean "no internet connection"?
01 Jan 2025 10:23 PM
No Internet connection - what's confusing is it has been working pretty well for the last 2 weeks. So I'm asking myself why is the problem occurring now?
