Discussion topic: Noisy Hub
This message was authored by: 86andcounting
Noisy Hub
My Sky HUB KEEPS MAKING A LOUD BEEPING NOISE. can't find how to correct it
Re: Noisy Hub
@86andcounting
As far as I'm aware, Sky Hubs don't contain any speakers: the most noise they can potentially emit is the whine of solid state electronics or the click of an electromagnet relay circuit.
I'd suggest temporarily pulling the Hub power supply out: if the beeping continues then you can be fairly sure it's not the culprit.
