1
Discussion topic: No yellow cable with router
This message was authored by Janet2023 This message was authored by: Janet2023
Is there suppose to be a yellow cable included?
This message was authored by Chrisee This message was authored by: Chrisee Answer
Re: No yellow cable with router
@Janet2023 the cables supplied vary according to the type of connection the hub will be used with. The yellow cable - actually its a standard ethernet lead - is inly required if you are having a full fubre service. Services over a copper phone line  use the purple cable.
Either type can be bought easily locally in most any hardware store or larger supermarket either an ethernet cable with rj45 plugs or a dsl modem cable with rj11 connectors.
