Discussion topic: No wlfi
This message was authored by: MazT70
No wlfi
Last couple weeks WiFi keeps going off about 5 times a day ,daughter trying to study from home its so frustrating!! App says no issues!
Re: No wlfi
@MazT70
Wi-Fi or broadband? They are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
