Discussion topic: No wifi
This message was authored by: PhoenixWolf
Message posted on 02 Sep 2026 09:22 AM
No wifi
There is no WiFi. TV is working but there is no WiFi I have rebooted the router twice and unplugged and plugged into a different plug but there are no lights on the router
Find out more
Message posted on 02 Sep 2026 10:21 AM
Re: No wifi
Do no lights appear if you connect it to a different power outlet, if so you will need to call Sky about this as you might need a replacement.
