Discussion topic: No wifi
Message posted on 30 Aug 2026 08:12 AM
No wifi
Message posted on 30 Aug 2026 08:14 AM
Re: No wifi
@Kearton
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
