Discussion topic: No wifi
Message posted on 14 Aug 2026 02:31 PM
No wifi
I've had to go onto 5g just to open the my sky app!
Message posted on 14 Aug 2026 02:34 PM
Re: No wifi
@Simmi33
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
