Discussion topic: No wifi
This message was authored by: Kim226
No wifi
I have no Wi-Fi connection for the tv , I have a flashing red light on the plug that is connected to the router
Re: No wifi
@Kim226
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
