Discussion topic: No wifi
This message was authored by: rhea2025
No wifi
You are telling me everything is good, this is not the case at all . We have no WiFi on any of our devices
Re: No wifi
@rhea2025
As we are customers here who help each other you are not talking to Sky.
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
This message was authored by: Stef3098765
Re: No wifi
Me either box has red light
Re: No wifi
@Stef3098765
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
