Discussion topic: No wifi
This message was authored by: Nowifi2
No wifi
WiFi hub only showing red light have re set it but still showing red light
Re: No wifi
@Nowifi2
You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is made up predominantly of Sky customers helping other Sky customers with additional help from Superusers like myself.
This link explains the lights on the various hubs
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
