Discussion topic: No wifi
This message was authored by: Kayleigh119
No wifi
WiFi signal consistently dropping signal, tests say nothing is wrong however it affecting multiple devices. I have restarted the router and the issue is still the same
Re: No wifi
@Kayleigh119
Are these devices near your hub when this happens or are in they different rooms or on different floors ?
Avatar for Kayleigh119
Re: No wifi
All different rooms including one in the same room. Thank you ☺️
