Discussion topic: No wifi
Message posted on 04 Aug 2026 07:54 PM
No wifi
Message posted on 04 Aug 2026 07:55 PM
Re: No wifi
you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
