7
This discussion topic has been answered Discussion topic: No wifi
This message was authored by: KT222
No wifi
WiFi has been down since 1137pm last night. Service checker says no issues in the area followed all the troubleshooting steps and still no connection?
Avatar for KT222
This message was authored by: KT222 Answer
Re: No wifi
Seems to be back up and running now (fingers crossed)
Re: No wifi
@KT222
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Avatar for KT222
Re: No wifi
Thank you for your reply. Despite online saying there are no issues called and they said there was an issue but didn't know when it'll be resolved. It seems to be the whole area.
This message was authored by: 34sboy
Re: No wifi
Hi, which area are you in?
I'm in West London, Hillingdon and I've got no Internet this morning. Status shows fine.
Re: No wifi
@KT222
Sky usually quote 2 WORKING DAYS as a potential fix time because of the service level agreement in the UK between ISPs and Openreach for fixing a domestic fault.
Some repairs take longer, for example when a pole or cabinet has been damaged or the road needs to be dug up (once they’ve obtained permission from the local council).
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it. This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from April 2026 the rate has increased to £10.34 for every complete day).
▫️There is no equivalent scheme for customers in the Republic of Ireland.
▫️There is no automatic compensation for TV services affected by a broadband fault.
▫️Sky broadband discussed here is a domestic service so whilst Sky allow customers who work from home to use it for that purpose they won't receive additional or quicker support.
This message was authored by: Cookie3756
Re: No wifi
Sky Broadband also down, also based in Hillingdon, status checker does now show a known issue
Re: No wifi
Same issue, also in hillingdon
Avatar for KT222
Re: No wifi
