Discussion topic: No wifi
This message was authored by: Mumgyn
No wifi
Few hours ago, my broadband is working intermittently. Now it totally stop. No Internet connection. Service checker said no issue but I dont have WiFi.
Re: No wifi
@Mumgyn
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Re: No wifi
@Mumgyn
The service checker looks for outages in your area so will not show anything if it is an issue at your property only so try running this line test:
