Discussion topic: No wifi
Message posted on 13 Jul 2026 11:22 AM
No wifi
I was told to WiFi by you it as it would not connect to server on work laptop for any apps but WiFi was connected but now I can't get WiFi on any device at all. I have re seated all cables , reset and all lights are green on router
Message posted on 13 Jul 2026 11:23 AM
Re: No wifi
Please can you assist at all
Message posted on 13 Jul 2026 12:22 PM
Re: No wifi
Your post is a bit difficult to understand so are you saying your laptop will not connect to your wifi, if so what happens when you go into the network settings and select your wifi network ?
