Discussion topic: No wifi
Message posted on 10 Jul 2026 02:54 PM
No wifi
Message posted on 10 Jul 2026 02:59 PM
Re: No wifi
@Carl94
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
