Discussion topic: No wifi
Message posted on 06 Jul 2026 08:08 PM
No wifi
All sky checking systems showing working fine, no WiFi so no TV. Was told there was a known issue in the area that should have been resolved 1 hour ago, sky check shows no issues in the area.
Message posted on 06 Jul 2026 08:10 PM
Re: No wifi
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Re: No wifi
@Liz07
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Message posted on 06 Jul 2026 08:21 PM
Re: No wifi
