Discussion topic: No wifi
This message was authored by: Donna1900
No wifi
Have no WiFi. Has been bad for over a week now. I'm unable to use the TV unable to work. Please fix
Re: No wifi
@Donna1900  No one here can "fix" it as this is a customer helps customer community.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for Donna1900
Donna1900
No WiFi, better be working for the football later. The rooter has green amber green amber  on it. Not four green lights.
I messaged earlier today still no reply.
Re: Donna1900
@Donna1900  You're only talking to other customers, if there is a fault then stating it better be working later will have absolutely no effect on a fault.  It just doesn't work like that.
Creating a new thread won't help either, did you follow the steps in my reply to your 1st post?
