Discussion topic: No wifi
This message was authored by: Daniella16
No wifi
Morning it's 8.25 and I've done a WiFi checker as my box says no internet and you have said there is on the system so I switched everything off and back on again as suggested and still no internet connection.
Re: No wifi
@Daniella16
We haven't said anything yet. You haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
