Discussion topic: No wifi
This message was authored by: NikkiHunter
No wifi
I have no wifi
Re: No wifi
@NikkiHunter
Even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
