Discussion topic: No wifi
This message was authored by: Codiemorgan1
No wifi
Hi my wifi has stopped working
I have reboot and it's still not working
Re: No wifi
@Codiemorgan1
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
