Discussion topic: No wifi
Message posted on 10 Jun 2026 12:10 PM
No wifi
Message posted on 10 Jun 2026 12:15 PM
Re: No wifi
@ElenaDews
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
