Discussion topic: No wifi
Message posted on 29 May 2026 12:57 PM
No wifi
WiFi not working have turned off and on again twice and getting a red light on router box
Message posted on 29 May 2026 01:06 PM
Re: No wifi
@Victoria131
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
