Discussion topic: No wifi
This message was authored by: RM42
No wifi
The PON light is green on my ONT but LAN light isn't on and the Hub light isn't working so I have no WiFi.
Re: No wifi
@RM42
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
