Discussion topic: No wifi
This message was authored by: Scott19781
No wifi
Their is no internet in our house
This message was authored by: twothemax
Re: No wifi
I also have no Internet. The Power and Wifi lights on my Hub are green, the Talk one is orange and the Internet one is off.
Re: No wifi
@Scott19781 @twothemax
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Re: No wifi
The response from Sky it appears there's an issue with the outer line, which is causing the Wi-Fi to drop. If you're in London this may be the same issue?
Either way, they've escalated it to OpenReach
