Discussion topic: No wifi
Message posted on 10 May 2026 03:00 PM
No wifi
No WiFi for the past 2 weeks on and off and therefore need to book an engineer
Message posted on 10 May 2026 03:10 PM
Re: No wifi
@Natalie199
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
