Discussion topic: No wifi
Message posted on 05 May 2026 03:14 PM
No wifi
Message posted on 05 May 2026 03:28 PM
Re: No wifi
@Cardgs
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 05 May 2026 03:30 PM
Re: No wifi
@Cardgs if the PON light is out the optical,signal has failed to the ONT and reqvuires action by the network operator. If the Service Checker in the My Sky app run over a mobileconnection has picked up,the line drop which takes up,to an hour it will eithervtell you Sky arecaware of a fault or run through some tests before booking an engineer.
You need to be aware although you use your domestic connection for work that doesn't givecany priority and an engineer will probably be booked for Thursday. Calling Sky will get you thecsame result.
