Discussion topic: No wifi
Message posted on 26 Apr 2026 08:36 PM
No wifi
Message posted on 26 Apr 2026 08:40 PM
Re: No wifi
@Jades1504
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
