Discussion topic: No wifi
This message was authored by: Nici33
No wifi
No Wi-Fi and sky tv
Avatar for Nici33
Level 0 icon
Re: No wifi
Had no reply
Re: No wifi
@Nici33
That is because this is where customers help each other so isn't a live chat.
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
