Discussion topic: No wifi
This message was authored by: Sami19
No wifi
No WiFi in the house for the past 2 days. Please send the engineers
Re: No wifi
@Sami19
You can't arrange an engineer on here. You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
