Discussion topic: No wifi
This message was authored by: Km211
No wifi
I'm paying for absolutely rubbish for the last 2 months all it does it cut out 24/7 I use more mobile data than WiFi cause the WiFi is rubbish and I'm sick of it I'm paying for nothing I've been offered better WiFi from other companies that actually work
Re: No wifi
@Km211
