Discussion topic: No wifi
This message was authored by: Sarahprescott
No wifi
We have no WiFi broadband flashing orangeade green
Re: No wifi
@Sarahprescott
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Re: No wifi
@Sarahprescott
Your duplicate thread has been removed. You already have a reply on this one.
