Discussion topic: No wifi
Message posted on 24 Jan 2026 09:32 PM
No wifi
Message posted on 24 Jan 2026 09:52 PM
Re: No wifi
@Pamela12 And what do you see from the links below?
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Then later this one.....
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
