Discussion topic: No wifi
This message was authored by: Gingertom
No wifi
no Wi-Fi or telephone. Have 2 amber lights on hub
Re: No wifi
@Gingertom
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
