Discussion topic: No wifi
Message posted on 22 Nov 2025 03:39 PM
No wifi
Wifi down.
Message posted on 22 Nov 2025 03:41 PM
Re: No wifi
@Clarebrown
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
