Discussion topic: No wifi
This message was authored by: DanielBates
No wifi
My WiFi connection keeps cutting out saying no connection. This has happened for the best part of a week now. Can you please boost the signal or rectify the issue
Re: No wifi
@DanielBates
There is no option to boost a signal. By the way, you aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
