Discussion topic: No wifi
This message was authored by: Gareth40
No wifi
Ive woke up ans got no WiFi I work from home
This message was authored by: Chazzle
Re: No wifi
Same issue for me - orange light in internet and voice.
Can we get confirmation on whether this is an outage?
Re: No wifi
@Chazzle @Gareth40
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
