Discussion topic: No wifi
This message was authored by: Cathyd169
No wifi
Wifi has stopped working and we cannot reconnect, this is needed urgently for work
Re: No wifi
@Cathyd169
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
