Discussion topic: No wifi
This message was authored by: Catlady13
No wifi
No wifi connection
Re: No wifi
@Catlady13
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
