Discussion topic: No wifi
This message was authored by: Kamile123
No wifi
There is no wifi
Re: No wifi
@Kamile123
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
